Removing Lolly Column - Best Way
Old 05-27-10, 10:37 AM
I know what you're thinking just as soon as you read the title.
First let me say HI! and hope I find lots of good info out here.
On to my project. Removal of (2) lolly columns on a non-load bearing beam. I already had an engineer draw me up (2) flitch plates to install and they should be here in about a week. (Wanted to cover my bases so I paid the money to have it engineered to be safe).
So now my question is....what is the best/easiest way to get the lolly's removed and get the plates up to the floor joists? They weigh ~ 400 each and span 19'.
Needless to say this is going to be fun. I love construction and such and do 90% of my own work.
Hoping some folks out here have some good insight to share.
Thanks,
James
Old 05-27-10, 03:56 PM
Assuming your engineer is correct.........
With a sawzall or similar, cut around the steel at midpoint. The tube is filled with concrete(or should be), so only cut the steel. Pull out fasteners where the top plate joins the beam. A few well aimed blows with a sledge will break the concrete and make removal from the top easy. The bottom depends on how it is anchored. Most often, the bottom sits on a pad and is also easily removed.
Old 05-27-10, 04:47 PM
Just make sure you have completely supported the beam and walls well before the column removal, Some people knock out things before supporting and making the suggested reinforcement and wonder why there was more deflection and cracks.
Dick
Old 05-28-10, 04:50 AM
Dick
I can only imagine. Wow.
The plates will be installed and supported prior to the removal of the lollys.
