celing falling
i have a ceiling with cable heat in it. Thje ceiling as cracked and is sagging inthe center of the room. how do i resuspend the ceiling without damaging the cable heating system
Hello
Go to your local Electric suppy house and tell them what you are doing they have a little meater with a light that will come on when it is over a live wire, turn on the heat locate the wire turn of the heat and make a small hole very carfully and see how well it worked if OK then go on from there. 2. You should be able to find out who made the panel and they will have a diagram as to where the wire is installed for installation......Good Luck
