Window Well drain clogged
Old 10-23-10, 11:53 AM
C
Question Window Well drain clogged
My house was built in 1928. One window well (cinder block walls & cement base) is clogged with mud. I removed all the mud (3in) and all the rocks mixes with mud (6 more inches). I removed the cover at the bottom of the window well and found a mud impacted metal ball that the drain cover was screwed into. The ball seems to be hollow and the area around it is just muddy gravel. I removed as much of this as possible but water still does not drain. Anyone have an idea what is this ball's purpose? And what else i could do.
Old 10-23-10, 11:22 PM
window well drains are usually gravity & do not use pumps,,, we've installed, cleaned, replaced, & repaired them but never ran into a ' ball ',,, all i can guess is roto-rooter or replace it - could it be a drywell of sorts ? doesn't make much sense to me either but i'm grabbin' at straws,,,,,,,,,,,,,,,,,,,
Old 10-24-10, 05:37 AM
D
Received 1 Upvote on 1 Post
This is cover is to the drain? Is the cover slotted or solid?
Old 10-24-10, 06:41 PM
C
cover with 10 1/4 in holes
Cover is on a hinge and had a screw in middle (had to drill it out ) and it has about 10 quarter inch diameter drainage holes.
Old 10-24-10, 07:41 PM
XSleeper's Avatar
Received 1,812 Upvotes on 1,629 Posts
sounds like the ball could be a float, that if it wasn't all filled with mud, rock and gravel, the ball would float when there was a large amount of water, and when the water was gone it would close. But that's just a guess.
Old 10-24-10, 08:05 PM
C
photo try
Old 10-24-10, 08:24 PM
C
