Repair mortar cracks in block wall
Old 09-12-11, 02:44 PM
I have a Townhome built in the late 70's with a 'look out' lower level. It's about 4' below grade along two walls.
We tore out the old walls, and near one of the windows, there's a section of blocks about 24" wide where the mortar is cracked. A couple of the blocks are a bit above grade, and even though the cracks are narrow (less than 1/16"), you can see light through them from the outside.
What is the best method for repairing these cracks?
Landscaping is sloped well, but these blocks are located directly below a silcock for a water hose connection outside. I suppose that this is partially responsible for the cracking. Anyway, I need to have these blocks waterproofed pretty well since they'll likely be exposed to lots of water in the future.
Old 09-12-11, 03:50 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Preventing moisture problems in block walls is always best if attacked from the outside. I would locate the offending block on the outside, dig down as far as feasible, or as far as the cracks go, apply a cinder block coating and fiberglas, then more coating to ensure it is sealed. After a few days, you can back fill and taper your landscape back properly.
Old 09-13-11, 03:06 AM
we do the same - sonneborn's ' sonolastic ' is a good coating material but so is roofing cement applied w/trowel,,, we protect w/miradrain
Old 09-23-11, 09:01 AM
I'm going to dig down and address the cracks from the outside. From what I've read in other threads, hydraulic cement might be an option.
As I understand it, you open up the cracks a little bit more in a dovetail shape, then apply the cement and let it expand. Can someone describe the dovetail joint a bit more?
Old 09-23-11, 10:05 PM
E
Received 1 Upvote on 1 Post
Sounds to me that you would want to chip an inverted V so that the deeper into the block the wider the opening to allow the hydraulic cement to expand and not push out of the crack.
Old 09-24-11, 04:12 AM
chandler's Avatar
IF your cracks are large enough to utilize hydraulic cement. They may not be. If not, a solution as stadry1 suggested would be the best overall solution. It would make the entire wall waterproof and help shed water away from the entrance points.
