moisture in crawl space with sand floor
I live close to b each and lately have been getting quite a bit of water. This in addition to Irene. Do I put in sump pumps, open or close access door and windows in winter/summers. Space is three feet below grade and is five feet to joists. Thanks
Welcome to the forums
Moisture in the air in the crawl space or the sand is wet?
Is the plastic on top of the sand?
That is part of confusion. One contractor will say this is way to go, another will say if I get water on top or if so much water it floats out of place it is not worth it. Some say just pumps and ventilation would do the job. I want to do this myself, so need a manageable solution.
You need to put a VB in the crawlspace. Yes it will float but will be in place when the water is gone. your in a humid area letting moisture in from vents will only make it worse.
