Crack in basement floor
Old 03-28-12, 12:29 PM
I
Thumbs down Crack in basement floor
I have a poured concrete basement.
The original owner said that a crack in the floor was caused during construction. This crack runs the entire length (front to back) of the basement floor. Should this be a cause of concern?
Old 03-28-12, 01:12 PM
Received 1 Upvote on 1 Post
How old is the basement, how wide and is there a height difference between the sides of the crack?
What is the size of the basement?
Dick
Old 03-28-12, 01:23 PM
I
The basement is 7 years old, built with the house. It is about 1800 sq ft.
Old 03-30-12, 09:07 PM
BridgeMan45's Avatar
You didn't say whether the crack was settling differentially (higher on one side than the other), or whether it was moving or not. Tight cracks up to 1/16" wide are not unusual for the floor size you mentioned, and don't warrant any remedial action unless they're allowing water to get in. Or unless you're a worry-wart.
