Hiding piping in finished basement closet
Hi all,
I just bought a townhome and need help hiding some piping in finished basement closet. I've attached a picture. I'm not sure why they put carpeting around it, but can anyone offer advice on how to hide/cover up the piping? And shouldn't I add some type of floor cover so the dirt is hidden?
Thanks for any advice!
Jackie
Jackie
In my opinion you should not cover this in any way other then with something temporary like a curtain. I can't really tell if this is a sump pump (to remove water from the basement drain tile) or a ejector pump (for ejecting sewage). Easy way to find out is to run water in a basement bath or laundry tub and see if the pump starts. Anyway it should be left open do that it can be accessed later when the pump fails.
