basement wall insulation
ivader, or others
where can I find blanket insulation?
In Edmonton, Canada.
thanks,
originalhorsetrade
thanks,
originalhorsetrade
Originally posted by originalhorsetrade
ivader, or others
thanks,
originalhorsetrade
ivader, or others
thanks,
originalhorsetrade
Try locating a Building supply near you, sometimes Home Depot does not carry everything you need. The Home Depots out here (NY) carry Blanket insulation....but limited in your choices (R Value).
Your local Building supply should carry alot of different blanket insulation.
Good Luck
Lvaders
Good Luck
Lvaders
