Soffit advice
Old 06-01-13, 09:09 AM
T
Soffit advice
See pic.
I am planning to put the "ladder" of the soffit on this side of pipe to conceal the pipe coming out of ceiling. Correct plan?
Old 06-01-13, 09:52 AM
czizzi's Avatar
Received 15 Votes on 13 Posts
What is the point of covering the top of the pipe when the bottom is still visible. I would build a wall from floor to ceiling and completely encase the pipe.
Old 06-01-13, 10:04 AM
T
Angry
Can't really build a wall in that spot. I was going to box in the pipe in a column though.
Old 06-01-13, 10:12 AM
XSleeper's Avatar
Received 931 Votes on 850 Posts
The cleanout must remain accessible. If enclosed in a column, it must still have a cleanout cover plate.
Old 06-01-13, 10:21 AM
T
Yep. Know about the clean out
Old 06-02-13, 11:51 AM
T
Anyone else to comment on?
Old 06-02-13, 12:26 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Yeah, build the column around it and modify the top part to cover the wye and build a door for the cleanout. You mentioned "soffit", and I was initially thinking you were building a long soffit across this entire area. I would just box in the offending pipe and move on.
And we did this back in March, too. http://www.doityourself.com/forum/ba...lp-needed.html
Old 06-02-13, 12:49 PM
T
I am talking about a soffit going from left of wye to cover beam and ducts. Then building column around pipe. In march I was thinking about a wall but am just going with 2 columns. I just wanted advice on whether to encase the wye part of pie into soffit or not.
Didn't know I was irritating you with my questions. I guess I will go to other sites.
Old 06-02-13, 04:21 PM
XSleeper's Avatar
Free advice...good advice... not sure what seems to have offended you.
Old 06-02-13, 07:43 PM
chandler's Avatar
You didn't offend me. I can't be offended, sorry. I believe if you read the March posts, the matter of the pipe was addressed via a wider wall. However, if that's not in the works, now, then so be it. I just didn't want to fight to gain the same ground twice. What type ceiling are you planning?
Old 06-03-13, 06:55 AM
Z
Received 196 Votes on 176 Posts
If it were me, I would build a 2' wide (approx) soffit from the staircase past the pipe to cover the pipe and beam, then narrow it down to a 1' wide soffit for the rest of the run to cover the beam. I don't like rooms with a whole lot of jut-outs. I'd rather lose a bit of ceiling space than having these 'random' boxes... but that's just my opinion.
Old 06-03-13, 07:28 AM
czizzi's Avatar
I guess the plumbers can comment on this.....
Why the wye? Couldn't the drain be reconfigured with a sanitary tee, have the connections done inside the joist cavity? Why does it come off the toilet at 45 degrees. Would make for a cleaner install on the columns and eliminate the need for the soffit.
