1967 Attic Insulation Question
I live in Michigan and I've just purchased my first home. It's a 1967 ranch and during the home inspection I saw that the attic does not have pink fiberglass insulation. Instead it has loose gray stuff in between all the ceiling joists.
If I choose to better insulate the attic, do I have to remove the old gray material first or can I insulate over it with pink fiberglass?
What R value of pink insulation would I need if I'm able to put it over the gray insulation?
In general is this old gray insulation considered very poor and should insulating my attic be a first order of business?
Thank You!
Ken
Thank You!
Ken
Received 0 Votes
An attic that was insulated in 1967 is not up to 2001 standards. There is no reason to remove the existing insulation -- just add more over it. But before you go out and spend hundreds of dollars on fiberglass batts, get a couple of extimates to have cellulose blown in by a pro. I think you will find there isn't a great deal of difference in the number of dollars you will spend. However, the pro will blow an attic in less than a day. You will spend a week or more crawling around in the attic to get the batts placed. And the blown cellulose will give you a better job, with few, if any, air pockets.
Received 0 Votes
The insulation code for Michigan is R-38. You will need to know this when you talk to the cellulose insulation people.
do not even mention you have some insulation there. Just put in R-38 all over. You will notice a difference. The cellulose works terrific. The only way to go.
