Help designing basement
Old 09-11-13, 11:30 AM
I was wondering if anyone could help. I am going to finish my basement. I have no clue on how to lay out and position rooms, etc. I have attached the outline. Would anyone be willing to draw out some rooms for me?
Our needs are:
Bedroom
Bathroom
craft area
office
home theater
kids play area.
File Type: pdf
Old 09-11-13, 06:31 PM
Helllooooo? Someone? Help!
Old 09-12-13, 05:48 AM
W
Received 61 Upvotes on 53 Posts
Drawing
Finish the drawing. Add dimensions, entrances, stairs, windows, labels, etc.
Old 09-12-13, 04:06 PM
OK, I will. Thanks a bunch. Check back
Old 09-16-13, 09:02 AM
Here it is
Take a look and tell me if you can't read it.
File Type: pdf
Old 09-16-13, 10:49 AM
W
Basement Floor Plan
Is there an exterior door? I do not see one in the drawing.
Old 09-16-13, 11:11 AM
No exterior door. Just the one at the bottom of the stairs. Thanks.
Old 09-16-13, 01:00 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
One thing will limit you. You must have an approved egress window in any bedroom, so that leaves out a vast majority of the basement for a bedroom. The bathroom stub out is not clear, but if you know where everything is, that's good. How will the effluent get to the ejector pump? I inverted the picture so the writing is right side up, so from where I am sitting, the window in the lower left corner shows 22". What is its height? Need to know the square footage of that window.
Old 09-16-13, 01:37 PM
That window is roughly 16" in height. The other larger window directly across and to the right( from the bottom of the stairs, facing into the space ) is 51"x60".
Old 09-16-13, 01:51 PM
chandler's Avatar
22"x 16" isn't enough for an egress window. The only place you can position a bedroom would be in the vicinity of the larger window. Does that window open? Just thought of that.
Old 09-17-13, 06:11 AM
Yes that window opens. That would be where the Bedroom goes
