Need another 15" clearance in basement
Old 10-03-13, 03:13 PM
I am looking at putting a golf simulator into my basement, but unfortunately I need another foot to be able to swing my driver safely. My ceilings are 8 feet now and a 9 foot ceiling would be perfect.
Is there anyway to cut into the wooden Ibeams and support them a different way. I would be swinging the same direction the Ibeams run if that makes sense, so being able to cut out the bottom chunk of just 2 of them over maybe a 6 feet span would give me all the room I need. However, I am kind of doubting there is anyway to structurally support this "hole" if I go ahead and do it.
Alternative 2 is to dig down, which is likely WAY too much cost for adding a winter toy.
Alternative 3 is to just use the bonus room upstairs with 12 foot ceilings but I really don't want to set it up in there.
Thanks,
Old 10-03-13, 03:49 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Hands down, door #3. The other two make compromises to your house and you don't even want to go there. Sometimes wants and needs settle out in the middle.
Old 10-03-13, 04:00 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Digging down will be way cheaper then cutting the floor joists...
Old 10-03-13, 08:08 PM
maybe cheaper, but likely still more then I want to spend on this project
Old 10-04-13, 10:54 AM
Received 1,231 Upvotes on 1,179 Posts
# 3 and then # 2, I wouldn't attempt # 1.
