Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Basements, Attics and Crawl Spaces
Reload this Page >
Concrete repair vs plywood floor over uneven concrete floor.
Old 10-11-13, 02:51 PM
A
Have an attached 12 x 15' workshop with a concrete floor. It used to be a carport which was walled in 1990. There are large cracks in the floor and the floor slopes down almost 3" on one side. It is not part of the house slab which is in pretty good shape. There used to be a water problem in the wet season ( I'm in the Pacific Northwest) but we have added drainage around this addition so the floor is now dry. It would be cost prohibitive to use floor leveling compound ($900). I was thinking of leveling with thin set then a mixture of sand and portland cement as advised by a concrete tech, but our contractor is inclined to shim it with treated wood and create a plywood floor. The advantage of plywood is that the floor would be warmer in the winter. Any thoughts?
Old 10-11-13, 03:17 PM
XSleeper's Avatar
Received 1,960 Upvotes on 1,757 Posts
Tapered sleepers and a 3/4 t&g floor is probably the way to go if you aren't inclined to bust out the floor and start over with a new insulated and level conrete pad.
Old 10-11-13, 03:50 PM
Received 1 Upvote on 1 Post
As you have been told on a few web sites. Plywood should never be used in direct contact with concrete.
No pressure treated plywood should be used in an occupied space.
It's pretty clear that no one did any proper prep work when poring this slab.
Want it right? Cut out the old slab and start over and do it right this time.
Old 10-11-13, 07:36 PM
A
Thanks xsleeper. Definitely do not want to bust out the floor. Have already spent a lot of $ busting out other areas of concrete to make a new entry way--plus did my own removal using a sledge hammer. No fun at all. When you say T&G are you referring to some kind of T+G subfloor/plywood?
Came across this idea of shimming perpendicular to slope which would make things simpler.
Workshop Flooring | The Down To Earth Woodworker
Old 10-11-13, 09:26 PM
G
I got a chuckle when at the end he said; might want to add a vapor barrier too....lol. In Wisconsin no less on an older garage slab probably without a poly vapor barrier underneath. With surface temps from 40-48; Average Shallow GroundWater Temperatures | Ecosystems Research | US EPA
Read second page, summer condensation; http://www.buildingscience.com/docum...g-your-basment
Gary
