Shelf Wall in basement
Received 0 Votes
I have 2 drain pipes that I framed into wall except for the bottom portion going into the floor. I didn't want to lose more room by framing the wall in front. So instead of boxing the two pipes I decided to build a short wall in front of them creating a shelf even with the window. But I have not done correctly thus far. See pic. Any help? I was thinking just drywall over but how considering the gap.
You can attach a strip of wood to the back wall along the face of the studs to provide a ledge along the back to attach your sheetrock. Another option is to sheetrock the vertical sections and make a wood shelf top for the horizontal portion.
Received 0 Votes
The end of that wall needed to be framed like one of these to tie it into the back wall.
framing intersecting walls - Bing Images
Sure looks like you may have been able to use a 2 X 6 instead of the 2 X 4 for a top plate also so the two could be nailed together.
