Basement framing help
My basement was flooded by hurricane Sandy. It was gutted and cleaned by previous owner. They also put down large rectangle tiling throughout the basement. I was gonna wait a year to refinish, however decided now is the time to do it. I plan on doing most of the work myself, except for some plumbing and the taping. I am unsure if whether to use wood or metal studs. I've never worked with metal studs before? I am also not sure how to deal with the tiles, pre-drill thru tile with ceramic bit then hammer drill thru cement floor. Or could I get away with liquid glue? Since no walls will be bearing any weight? Not really sure? Any suggestions would be greatly appreciated!
Wood studs, pressure treated bottom plate, Tap-Cons or Ram set to attach bottom plate.
No glue needed.
If you use the search function you'll find at least 1000 post on basement framing and insulation.
No glue needed.
