Perimeter Drain Tile Inspection?
Old 01-15-14, 12:10 PM
I have a sump pump with two 4" corrugated pipes that feed into the sump pit. I assume these are part of an exterior perimeter drain tile system. Home was built in 2001. One of the pipes feeding the pit is always dry so I suspect a problem.
Couple of questions:
1.) Are there ways to test if a portion of the drain tile system is blocked?
2.) Are there way of determining where the blockage is without using an inspection camera?
3.) If I find a place to rent a sewage inspection camera how hard will it be to perform the inspection myself?
Thanks!
Old 01-15-14, 09:10 PM
Received 16 Votes on 14 Posts
1. Only if you know where the drain tile is/runs and have access to the inlet.
2. None that I know of.
3. The camera and connection is pretty flexible so it is mostly just a matter of doing it. Finding the camera to rent may be a bit difficult and you really want a video recording of the inspection as you can easily miss things on the initial view.
