Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Basements, Attics and Crawl Spaces
Reload this Page >
Vapor barrier needed with 2" Rigid Foam Insulation
Old 02-24-14, 09:25 AM
srburns's Avatar
Hi All
Planning to redo a basement foundation wall. The plan is to use 2" Extruded Polystyrene Rigid Insulation against the foundation wall. Then build a typical 2x4 stud wall with bat insulation against the foam wall then drywall.
My question with this build is, do I need a vapor barrier on the stud wall before I hang the drywall? I have heard mixed views if it is needed since I will be using 2" foam.
I have looked at the sticky above, but all the links land on a generic home page.
Old 02-27-14, 06:35 AM
srburns's Avatar
Anyone help me out with this? Toronto Canada area if it helps.
Old 02-27-14, 07:19 AM
B
Received 37 Votes on 34 Posts
Hi sr,
The real answer will come from your local code authority, which varies just as much as the opinions you have already found.
My position is no vapor barrier below grade to allow a small amount of drying through that 2" poly. 2" is not very permeable and some will consider it a VB. I've attached a link on vapor diffusion retarders. But vapor is much different from moisture. If you have or have had any water problems, they must be corrected first, usually (best) from the outside.
If a class I vapor retarder such as poly is applied to the inside at any point, you can expect the moisture directly behind the plastic to accumulate, all-be-it slowly, until it matches the soil outside and that is usually sufficient to grow mold. By allowing a small amount to pass through the foam, it reduces the moisture build up.
So, IMO, no additional VB is required. But many code officials will disagree.
I also attached a link on basements. Photograph 4 illustrates what you described and also answers your question.
Vapor Barriers or Vapor Diffusion Retarders | Department of Energy
BSD-103: Understanding Basements — Building Science Information
Good luck and sorry I didn't catch your question when posted.
Bud
