Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Basements, Attics and Crawl Spaces
Reload this Page >
Basement Water problem/ how to repair/ what is the best solution?
Old 04-09-14, 03:00 PM
R
Question Basement Water problem/ how to repair/ what is the best solution?
dear all, would like to get your help/ input and suggestions, what way can i repair this? what is the best way? some people/ friends have said insulate from inside with drylock and etc.
what would you suggest?
thanks all in advanceName:  IMG_3103.jpg
Size:  18.0 KBName:  IMG_3104.jpg
Size:  22.2 KBName:  IMG_3105.jpg
Size:  23.3 KBName:  IMG_3106.jpg
Size:  16.3 KBName:  IMG_3107.jpg
Old 04-09-14, 05:42 PM
Received 94 Votes on 83 Posts
Keep the water away from the wall on the outside through grading, gutters and downspout extensions - the answer is not a coat of paint on the inside trying to stop water that's already 95% of the way through.
Old 04-10-14, 05:53 AM
Norm201's Avatar
Received 254 Votes on 228 Posts
What Mitch said.
Also, do you have water flowing into the basement? If so you can do several things. You can drill a hole into the floor. And/or you can chisel a groove into the wall (a reverse dovetail shape) insert a wicking media like string or a small tube going into the hole at the bottom and then using a hydraulic cement (Fast Plug comes to mind) and covering the groove.
