Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Basements, Attics and Crawl Spaces
Reload this Page >
Do my basement walls contain a poisonous substance?
Old 07-13-14, 06:53 PM
Question Do my basement walls contain a poisonous substance?
Size:  35.7 KBName:  IMG_20140627_153456.jpg
Size:  21.3 KBName:  IMG_20140627_153504.jpg
Size:  23.5 KBName:  IMG_20140627_153507.jpg
Size:  28.6 KBName:  IMG_20140627_153441.jpg
I recently moved into this 1910 home in the Pacific Northwest (just north of Seattle). The basement walls have a chalky material that is flaking off of the block walls. I've tried to leave it undisturbed, but my wife thinks it's getting worse. Any ideas what's going on?
Many thanks!
-Jacob
Old 07-13-14, 06:59 PM
Tolyn Ironhand's Avatar
Received 352 Votes on 304 Posts
Welcome to the forums!
Google "efflorescence". It is harmless.
Old 07-13-14, 07:33 PM
Received 1,530 Votes on 1,413 Posts
Your wife is probably right..... it does get worse with age and as more moisture seeps thru.
Old 07-14-14, 03:30 AM
Received 408 Votes on 364 Posts
The cosmetic fix is to scrape and repaint but it will return unless the source of moisture is addressed. Sometimes that can be as easy as routing the downspouts so water is directed away from the foundation. Regrading might be needed, worse case scenario would involve excavating along the foundation sealing the wall and installing drain tile.
