Support/Carrier beam help
Old 07-20-14, 12:10 PM
L
Post Support/Carrier beam help
I am in the process of building a cabin which has a loft bedroom in the attic area. I want the area below the loft bedroom to be open and needing help determining what size of I beams to use to carry the wieght of the loft/attic bedrooms. The cabin is 26 ft. wide and I am wanting a 24ft open space. I will have two carrier beams because I have a centered door in the end of the cabin so a one beam design won't work as well. The beams will be place at 8.5ft from the outside side walls and be 24ft long. So how big do I need to make the i beams to carry the load spanning the 24 ft? thanks
Old 07-20-14, 06:05 PM
P
Temporarily Suspended
You really need an architect to design that for you. I doubt that you will get an answer here.
Old 07-22-14, 04:30 PM
BridgeMan45's Avatar
Received 1 Vote on 1 Post
I'm not an architect, but there's not enough information for even an engineer to tell you what's needed. Your description makes it sound like you're trying to build a complete upper floor, and not a loft (which could be carried by just one beam, with ledgers around the perimeter). How long and what spacing will the joists be at that are resting on the beams?
