Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Basements, Attics and Crawl Spaces
Reload this Page >
How to make my basement ceiling not look like one!
Old 08-26-14, 07:10 PM
I have beams on the ceiling of my basement but also wires, piping, ducts, etc. Can I spray foam it? Can I paint it all with a sprayer? How can I make it look less basement-y? Thanks!
Old 08-27-14, 03:16 AM
Received 403 Votes on 359 Posts
Welcome to the forums!
I've sprayed several exposed basement ceilings, generally darker colors look best. When you paint them white all the cracks and shadows show while darker colors will hide them.
I don't know a lot about spray foam but I think code requires it to be covered. I don't know if paint is a sufficient covering. Also it would embed all your plumbing and electrical which could be an issue if you need to do any work.
Old 08-27-14, 05:45 AM
Received 98 Votes on 86 Posts
Unless it's outside space above your basement, I wouldn't put any insulation in the ceiling (plus the access issue to pipes and wires it would create, as Mark said). If you don't want to install a drywall or drop ceiling, I'd paint it flat black.
