Cap on basement stair rail
Finished the entire basement. Came out beautiful. Only thing left is caulking, some trim paint and the stairs. On the stairs I have a half wall that I left open on the right as you walk down. I capped it with a piece of 1x6 I believe with a 3/4 inch over hang on each side. I planned on putting a strip of finishing molding running under the overhang on each side. Problem is I guess 3/4 of an inch isn't enough. The finish molding sticks out further than the overhang. Should I rip this thin piece of finishing molding or just put it on run and blend it in with strip of caulk ? Suggestions.
Try shoe molding. It is only 1/2" in the small dimension. American Wood Moulding WM 129 11/16 in. x 7/16 in. x 96 in. Wood Primed Finger-Jointed Shoe Base Moulding-129-PFJ8 at The Home Depot
