Huge foundation wall crack with water
Old 10-02-14, 08:50 AM
[ATTACH]
39238
[/ATTACH]
At least 5 ft long and in places up to 3 inches wide and deep. I believe the daily water flow is from the neighbor's underground sprinkler
Note the slight bow at the top of foundation. Should I call in a structural engineer?
What are my best options with regards to the crack ?
Old 10-02-14, 12:36 PM
A pretty vague description and a poor photo that begs rotating in some way. - Hard to give a recommendation without knowing if the wall is block, precast panels or poured in place.
since you have a deflection of the wall, call either a civil or structural engineer as a place to start. That will give you an idea of the importance and some ideas.
It may be due to a high water level/table or surface water. If there is a natural surface slope of the site, you might want to look at either deflection of the surface water or drain tile if you have a place to divert the water to.
Dick
Old 10-03-14, 07:55 AM
Received 1 Vote on 1 Post
sue the *******s :-) how dare they ? looks like a block wall from,,,,,,, hell, who knows ? those pics suck,,, if i were you, i'd pay attn to dick's advice 1st,,, you really don't know what material was used in building your bsmt wall ? ? ?
as a practical legal issue, IF your neighbor deliberately adds specifically AND directly to your structure's drainage water problem, you may have an actionable issue,,, IF his house/property's higher than yours ( as is OUR neighbor's ), you're outta luck !
