Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Basements, Attics and Crawl Spaces
Reload this Page >
BIN as a vapor barrier for plaster over concrete basement wall
Old 11-16-14, 12:24 PM
C
Hi All,
I've already started to furr out existing plaster over concrete basement walls and did not install foam board insulation. That said, even though my basement is dry, I'm wondering if I should re-paint the 50's era plaster over concrete walls to ensure a vapor barrier. I've been told BIN primer is good for this. If so, will I need to top coat if the wall is sealed behind insulation and drywall anyway?
Thanks...
Old 11-16-14, 02:41 PM
B
Received 37 Votes on 34 Posts
Not sure what you have for layers, but the question about having a vapor barrier over a below grade basement wall is "none". There is always moisture in the ground outside and without a direction to dry it will accumulate inside the concrete until it matches the soil. Allowing the wall to dry to the inside represents a very small amount of moisture but limits that accumulation.
Bud
