Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Basements, Attics and Crawl Spaces
Reload this Page >
Cutting a concrete crawl space wall to install an exterior door
Old 12-02-14, 09:41 PM
Help!
I'm wanting to add an exterior door to my crawl space, But were I want to install it their is a limited amount of space, so I would have to cut the concrete wall about 3" from a corner.
I'm not sure if it's a good idea to cut it so close to the corner.
I've attached a few pics and a Video to help show you what I'm thinking of doing.
The house is built on a small hill about a 10' drop. The exterior door landing will be at ground level.
Name:  1_Shows both weight bearing walls.jpg
Size:  34.3 KBName:  2_Shows the 2nd weight bering strucher .jpg
Size:  30.7 KBName:  3_Shows new 2nd weight bering structure proposal.jpg
Size:  30.6 KBName:  4_Shows new 1st weight bering structure proposal.jpg
http://youtu.be/elf9gJzkeko
Old 12-03-14, 05:21 AM
W
Received 34 Votes on 31 Posts
Door Opening
Because you have a concrete garage floor above, I think you should hire a structural engineer for advice.
Old 12-03-14, 07:42 AM
Your the second person that has suggested that.
It may make more senses to just relocate on the other side of the house which isn't a weight bearing wall, rather then messing with the foundation integrity.
Thank's
