Gluing EPS foam to a block crawl space wall
Old 12-04-14, 02:05 PM
Grady's Avatar
Received 35 Votes on 33 Posts
I want to insulate my crawl space walls & was going to use 2" foam board. What glue should I use? I know I'll have to clean the walls with a stiff brush prior to gluing.
Old 12-04-14, 02:25 PM
lawrosa's Avatar
Super Moderator
Received 69 Votes on 61 Posts
Item #7 here grady...
How to Install Rigid Foam Board on the Walls of a Crawl Space | Home Guides | SF Gate
Although my foam in the crawl was installed with masonry nails...Not very good IMO. I have to redo my vapor barrier anyway so it may all be coming down...
I would hate to think how I would remove it if it was glued.
Old 12-04-14, 04:28 PM
Grady's Avatar
Thanks Mike, I used a Liquid Nails product a bunch of years ago on my pump house but I don't remember which product it was. Certainly don't want something which is going to eat the foam.
Old 12-04-14, 04:42 PM
B
Received 37 Votes on 34 Posts
If you are going to cover it with a fire rated material, some codes require it, then you might consider one of the foil faced foam products. Dow's Thermax is one with a good rating, but be sure your local code accepts it. Tape all seams and cut edges with foil tape.
Bud
Old 12-05-14, 01:23 PM
Grady's Avatar
I don't think local codes require it but I'll check with a buddy who is a local inspector for the county.
