Hole is basement floor
Old 12-22-14, 05:27 PM
U
I recently had a radon test done on my home and it came back at a level of 5.2, which is above the EPA recommended 4.0.
I did a little looking around for possible area that could be the culprit and found this in the crawl space under the stairs near the furnace.
[/URL]
http://i1122.photobucket.com/albums/...ps4397b0e9.jpg
Can anyone tell me what this is? or what purpose it serves?
Thanks
Last edited by Pilot Dane; 12-22-14 at 05:39 PM. Reason: edited to show photo in post
Old 12-22-14, 05:43 PM
Received 98 Votes on 86 Posts
Sump pit - water drains around your foundation into to be pumped outside somewhere.
The lack of a pump tells me you may not have a water problem (I don't have a pump in mine, either).
Old 12-22-14, 05:56 PM
U
Ok thankyou
Since i dont have or need a sump pump (never had any water issues in the basement), is it okay to somehow seal that hole up to eliminate that as a possible place radon could be coming in?
Old 12-24-14, 12:15 PM
Received 1 Vote on 1 Post
if there are threaded nuts attached to the pit flange, you can buy a cover to fit from ferguson or zoro online,,, comes w/foam gasket strip, too,,, if not, put a cover on it & seal w/silicone so IF you need to access it in the future, it'll not be a horrible task
