New Basement Floor
Old 12-24-14, 04:25 AM
P
New Basement Floor
Planning to use Quikrete to pour around this drain clean out, then want to use a self-leveler to level the entire floor in the room. Is there a recommended time that the Quikete should cure prior to topping with the leveler-primer followed by the leveler? Thanks for the help!
Old 12-24-14, 12:18 PM
Received 1 Vote on 1 Post
bagg'd conc's a good idea,,, just be certain your hole has CLEAN square/vertical sides. ' self-leveling' isn't however, IF you have a crew who knows the work, its not all that difficult - that's why its a specialty item that most contractors won't touch,,, depending on your project, you MAY dodge a bullet & it'll turn out ok but we don't even attempt that item ourselves
