Need help with foundation cracks.
Hey all ... I've been posting a lot lately, but I have a major concern and I really need an expert eye on this.
I have a massive crack that goes from wall to wall in my basement that I was going to seal.
From the internet I knew I had to widen the edges before installing a sealant. However, as soon as I started chiseling it, I realized two things: 1. it was much deeper than I realized and 2. There's some exposed plastic line running along the crack.
As I examined this further, I found that there's a thinner crack in my basement, running perpendicular to it, that goes the other length of my basement:
I am now REALLY concerned that my foundation slab is splitting into four pieces. Is it? Should I call someone to look at this, and if so, what kind of company?
Thanks.
Thanks.
Yes, your slab is splitting into four pieces. Just like it is supposed to. Usually control joints are grooves cut or troweled into the surface but in your case it looks like a plastic strip was inserted into the wet concrete. It creates a weak point so that when the slab cracks it does it in a controlled manner and with a more attractive sorta straight line.
Does the plastic in your floor look like a vertical strip and you are seeing the top edge?
