wobbly ladder
Old 02-24-15, 04:37 PM
wobbly ladder
When someone used a ladder to go up to my attic, they suggested that I make it stable by putting on two screws to hook onto the floor of the attic. I'm not sure what he was talking about.
Thanks!
Karen
Old 02-24-15, 04:41 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
What kind of ladder? .
Old 02-24-15, 06:09 PM
F
Received 36 Votes on 28 Posts
If you are referring to a wooden ladder being wobbly you need to tighten the metal stay rods beneath or through each step or rung.
Old 02-25-15, 03:32 AM
Received 403 Votes on 359 Posts
As Ray asked, what type of ladder? [wood/aluminum, step/extension] also what size?
Old 02-25-15, 04:30 PM
wobbly ladder
It is a small wooden ladder-I can't get to it now so I don't know what size-maybe 5 rungs? I don't believe there is anything wrong with the ladder. As I said a carpenter suggested two screws so it has something to hook onto in the attic.
Old 02-25-15, 06:09 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Small wooden ladder doesn't answer the question. Is it a step ladder that opens in an upside down V? Or is it just a straight ladder that has to lean against something?
Old 02-25-15, 06:54 PM
ray2047's Avatar
A picture of the ladder and the attic opening would help. http://www.doityourself.com/forum/li...rt-images.html
Old 02-26-15, 05:11 AM
5 rungs would indicate a 5' ladder, most likely a step ladder. Since the typical ceiling is 8' higher than the floor I fail to understand how securing it to the attic would work. Sounds like a taller ladder would make getting in/out of the attic safer/easier.
Old 03-01-15, 03:00 PM
It is a straight wooden ladder that has to lean against something.
Old 03-01-15, 04:03 PM
How long is the ladder? At 5' it would never reach the attic is it homemade or cut from a section of a taller ladder?
A pic showing how the ladder is being used to access the attic would really be helpful!
Old 03-01-15, 04:19 PM
K
At the risk of sounding negative, I would just buy a new ladder. A small articulating ladder is great for all jobs around the house, can be used safely in several positions or heights, and is fairly inexpensive.
