Framing in basement
Old 03-09-15, 07:47 PM
B
Framing in basement
New to the forum and new to finishing a basement. We just purchased our first home and the basement was all finished but one 29 foot long wall. I am using 2 inch foam board and traditional 2x4 framing everywhere except for maybe one place and this is my question. At the bottom of my stairs I only have 3 feet from stairs to block wall. I don't want that wall coming out 6 more inches because I wouldn't be able to move anything down there. What are my options i put up 1/2 inch foam board on that 8 foot of wall at the bottom of the stairs. Can u use 1x3 or 2x2 to frame that portion to conserve space?? thanks for listening
Old 03-09-15, 07:50 PM
XSleeper's Avatar
Received 942 Votes on 860 Posts
When limited on space, one of the methods I will use is to cover the wall with 3/4" XPS foam horizontally, attach vertical 1x4's through the foam, then more 3/4" foam vertically between the 1x4.
By the time you put 1/2" Sheetrock on, it only takes away 2" of space.
Old 03-09-15, 07:54 PM
B
should i worry about doing all that drilling into my foundation wall?
Old 03-09-15, 07:57 PM
B
basically right now when I walk down my stairs and get to the bottom I have 3 feet to my wall. If I would do traditional 2x4 i would make that wall 6 inches closer to the bottom of the stairs. It would be very hard to get furniture moved down there if I made it that much tighter to go around that corner
Old 03-10-15, 06:09 AM
XSleeper's Avatar
Is it poured foundation or block foundation? You really don't need many fasteners at all... glue will do most of the fastening, and you only need a couple fasteners to hold everything into the glue.
Another way to frame a narrow basement wall is to use a 2x2 steel stud track, attach that track to the floor and ceiling, then place the studs flat inside the track.
