Stripping and sealing basement block foundation.
Any good ways to strip the paint to bare block besides power was or sandblast? This is an unfinished part of a basement, no ventilation other than HVAC and don’t want sand/dust in that. Ive been using a wire brush and scraper. Would a wire brush attached to a drill be better?
The white is the latest layer of paint, with the tan the underneath. The dark spot bottom right is bare block. I want to put a fresh layer of dry-lok on, and make it last.
A knotted wire brush in an angle grinder will really do the job....but it makes a heck of a mess and dust will fill the room, so you need eye protection and a respirator. Tape off any HVAC inlets/outlets.
Just to add some emphasis, if you can't address the water and moisture issues from outside, then they are not being addressed. Drylock is an attempt at slowing water penetration which will never be perfect, BUT, it doesn't block moisture vapor which, when finishing a basement or just controlling the mold issues, moisture vapor can be just as bad as water.
Blocks are another problem in that they provide a horizontal connection for most of the walls. A leak from the outside can travel 20 feet before you see it on the inside.
If you are just trying to reduce the humidity, the drylock is probably worth a try. The bigger problem would be covering those walls as part of a finished basement. That is when the moisture vapor slowly accumulates to become water which then feeds the mold.
Bud
Bud
Maybe, if you get the block cleaned enough you could do a few applications of whitewash. The lime is much more a deterrent to mold and mildew. You can find plenty of online recipes for brewing a batch and it is cheap to make. If you have a real water issue, then, as stated, the best solution lies outside.
a 4K psi pressure washer w/sand injection would work the best however you'll need water control + have a bunch of wet sand to clean up
