working in an attic with cellulose insullation help
Hello
New homeowner here. I would like to install a bathroom fan in the bathroom of my bungalow to get rid of moisture. The attic where there fan would go is very low and piled high with cellulose insulation, I am not sure what is the best way to work up there and searching did not give me good results.
Is it best to move it out of the way, work, then move it back ?
Can I just put a plywood board on top? Will compressing it ruin it or lessen the r#?
What do people usually do to work in attics as such?
Is a raised platform or something that does not disturb the loose insulation used?
I have attached some photos to show the insulation and the attic, full size available at Imgur (there is a fist/second/third)
Thanks for your help.
You'll be OK just moving the insulation away from your working area and then lightly pushing it back in place after.
Ensure any fixture you install is rated for IC, Insulation Contact. The IC rating should be clearly marked on the fixture. If there's any doubt of the IC rating, post back.
I wish all the attics I have been in had that much room!
You will compress it with your body/legs while working. Be sure to wear a dust mask as cellulose is VERY dusty, although I do not find it very itchy. When you are finished, fluff it up with your hands while you are back tracking to the scuttle hole.
I will check IC rate when I get home, thanks for the tip.
Seem like it's ok to both move and compress as long as I fluff it back to its space I guess
I will be venting out through the roof and not into the attic, correct.
Is its possible/recommended to put down permanent "flooring" up there?
Received 38 Upvotes
Yes, venting out the roof is the correct way. You should also insulate the exhaust duct to minimize any condensation, either internal or external.
