How to on making closed basement staircase into an open half wall??
I have been searching all over and cant find any step by step instructions on how to do this. I basically have a closed in stairway with drywall from top to bottom but would like to open up the bottom to look like this below. Nothing crazy and no expensive Banister or anything. Just something to open it up a little.
The half wall will wobble (if not right away... it will eventually) unless you put a tension device on the studs that make up the end of the wall. I would probably suggest you drill a 5/8" hole in the concrete then epoxy a long 1/2" threaded rod into that hole. Once the epoxy has completely set and cured, put a Simpson lateral tension device over the rod, and nut and washer both sides of the device. Screw the bracket to upper side of the stud first using all available holes. Tighten the top nut first. Then bottom nut last.
Drill the hole about 2 1/4" away from your end stud... and plan on adding a stud to fill in some of the space.
What's not clear from your pic is if the studs that make up the wall are load bearing, meaning if they are holding up a beam or other supporting structure above. From the built up post near the right of your picture it looks like there might be a beam above. Can you give us a shot or two that shows the framing in the ceiling above the stair opening and to the left of the stair opening?
I left myself enough yellow wire to move the switches and the other two wires would be moved in the direction they are are going to so they will have enough slack. Here is what i am thinking. Excuse my poor paint skills at work......
