Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Basements, Attics and Crawl Spaces
Reload this Page >
100 Yr. Old House - Stone Foundation - Can I Seal It?
Old 04-10-01, 02:56 PM
Jack45208
Question
I have been told that stone foundations must breathe & therefore I should never seal it. I was also told that if I did seal it, that I would harm the foundation. I have met a couple of people who've sealed their stone foundations & it's worked nicely for them.
Everytime we have a heavy rain, we always get water through the foundation and I'd like to seal it if possible. Please feel free to lend me your 2 cents worth on this subject.
Thanks in advance!
Old 04-11-01, 11:03 AM
The most common method of sealing stone walls is called Tuck Pointing. It is a slow tedious process, but it works really well. Alot of this is done on historical buildings.
You will need to read up on it. Library is the best source.
Old 04-25-02, 07:12 AM
Jack45208
Late Thank You Reply
Thanks for the reply to the question I posted, quite a while age. It's been a while since I last visited this site & wanted to let you know I appreciated your advice on my stone foundation.
Best regards,
Jack
Old 05-05-02, 08:53 AM
joebos2
JACK SEALING A WALL FROM THE INSIDE IS NEGATIVE WATERPROOFING. THE OUTSIDE PRESSURE ESPECIALLY WITH STONE FOUNDATION WILL EVENTUALLY PUSH IT OFF. WATER WILL FIND PATH OF LEAST RESISTANCE.
WE USE A VAPOR BARRIER ON WALL WHICH FLOWS INTO A WATER GUARD DRAINAGE SYSTEM TO PUMP. SUMP WILL REMOVE PRESSURE UNDER FLOOR AND SERVE AS DRAINAGE COLLECTOR. VAPOR BARRIER CAN BE CONNECTED TO WATER GUARD UNDER FLOOR. MORTAR ON WALL, SUPER GLUES ETC.ONLY TEMP.
CONTACT A BASEMENT SYSTEMS DEALER IN YOUR AREA THEY WILL SHOW YOU.
JOEW CERTIFIED WATERPROOFER
