Load bearing wall
Old 12-07-16, 01:42 PM
B
Load bearing wall
How do you tell if a wall is a load bearing wall?
Old 12-07-16, 01:59 PM
Received 98 Votes on 86 Posts
Generally will be perpendicular to the joist structure in the house, have a double top plate and be supported all the way to the ground.
Old 12-07-16, 02:02 PM
Received 99 Votes on 87 Posts
Look below and above the wall to see if there support above or below.
We have 0 info if this an inside, outside, wall.
What direction the wall runs in reguards to the floor and ceiling joist.
Single story?
Old 12-08-16, 02:11 PM
B
There are two different walls I am inquiring about.
Wall one:
Runs perpendicular down the middle of the house in the basement and I have attached two pictures of this wall, picture one and picture two.
Wall two: this wall runes parallel to the ceiling joists. Both of these walls are in the basement of a cape code house.
Thanks
