crawl space foundation musty smell
Old 12-15-16, 08:41 PM
D
when there is a good amount of rain, the musty smell is very strong in the living room and upstairs especially when the heater (central hvac) turns on...any idea to what might be causing the smell and what can be done to reduce or eliminate (the house does have a crawl space)? Thank you
Old 12-15-16, 09:29 PM
Received 1,267 Upvotes on 1,207 Posts
You need to find the cause of the odor. Is there water in the crawl space? Ducts running through there or anywhere else water might be coming in?
Old 12-16-16, 03:07 AM
Received 840 Upvotes on 737 Posts
I agree, you need to find the source of the moisture and eliminate it. Sounds like the crawlspace is the first place to look. Does the crawlspace have adequate ventilation? or is it closed/sealed up and conditioned by the HVAC or a dehumidifier?
Heat will often accentuate odors.
btw - welcome to the forums!
Old 01-21-17, 02:21 PM
A
Did you crawl down in there? What do things look like in there?
Old 01-22-17, 07:17 AM
Received 128 Upvotes on 113 Posts
Checked the ducts for air leaks?
Vapor barrier on the ground in the crawl space?
Working gutters?
Any standing water in the crawl space?
Grade running away from the foundation and no mulch or flower beds forming ponds up against the foundation?
