Gap between concrete slab and foundation
Old 06-10-17, 12:27 AM
Hi my basement suite has had ant infestations every summer and they seemed to be coming from this gap between the slab and the foundation.
I'm finally doing a renovation now and gutted the whole place so I'm looking for a way to seal it up around all the exterior walls.
Anyone have any ideas on what I can do? I've attached some images below.
Thanks
Size:  27.8 KBName:  IMG_20170609_182714.jpg
Size:  27.3 KBName:  IMG_20170609_182740.jpg
Old 06-10-17, 03:22 AM
Received 842 Upvotes on 739 Posts
I'd use a concrete caulk to seal it up.
Old 06-10-17, 11:25 PM
Hey thanks for the reply. You set me on a google search path and here is what I did. What do you think?
I ended up filling the gap with backer rod foam insulation and then sealing it with a latex concrete crack seal.
Foam backer rod
https://www.homedepot.ca/en/home/p.b...000156190.html
Concrete crack seal
https://www.quikrete.com/productline...ecrackseal.asp
