Fastening drywall directly to concrete?
Old 07-31-17, 10:38 AM
P
I've just finished framing out my interior and outside walls and getting ready to fireblock it all soon. And as I think about eventually sheetrocking, I do have one wall that I may need to place the sheetrock directly to the poured concrete wall and open to any suggestions.
This last wall is the one that is sort of a 'inside' concrete wall where my steps leading down the basement runs up against and butts up next to/below my garage. So it is not actually an outside wall exposed to the elements.
The main issue is that I have a 1 1/2 inches from side of the steps to the wall I could maybe get furring strips into the concrete, but may still have issues in potentially exceeding 1 1/2 and overhanging the side of step.
Since this is sorta of an inside wall, can you glue direct to the concrete?
Old 07-31-17, 10:40 AM
Received 330 Votes on 293 Posts
It's not a good idea! Concrete absorbs moisture and could cause issues with the drywall. I'd at least want to fur it out 3/4"
Old 07-31-17, 11:18 AM
Marq1's Avatar
Received 392 Votes on 366 Posts
The problem is there is no glue out there that will grab a hold of a heavy sheet of drywall without some mechanical fastening.
You should do the firing strips.
Old 07-31-17, 11:21 AM
XSleeper's Avatar
Received 712 Votes on 659 Posts
Since you have 1 1/2", I would probably glue sheets of 1/2" XPS to the concrete, followed by 1/2" x 1 1/2" plywood strips 16" on center on top of that (it won't be directly on the concrete that way), and then glue 14 1/2" rips of 1/2" XPS foam between the plywood strips. Gives you mostly 1" of insulation that way. Should give you 1/2" to install drywall. Use 3/8" rock if you have to.
Old 07-31-17, 11:22 AM
P
Thanks for the quick response and was answer I was expecting as well.
So I'll likely being added a few PT furring strips to that wall when I'm ready.
