Dehumidifier on separate circuit?
Old 08-29-17, 11:44 AM
D
Hi everyone. I'm taking estimates to install a central dehumidifier for my basement. So far I have four estimates and the latest one just mentioned running a separate circuit to run the dehumidifier on.
There is the blower/heater in the basement and the other estimates all said that they would tie into the existing line(the heater is gas). Is this normal or is it something that just adds cost?
Old 08-29-17, 12:21 PM
Received 98 Votes on 86 Posts
It would depend to me how much load was on the existing line being proposed and how much space is in the panel.
Old 08-29-17, 03:35 PM
Received 1,485 Votes on 1,373 Posts
The dehumidifier basically amounts to a small air conditioner. Your furnace is more than likely on a 15A circuit so it may be large enough to run the dehumidifier.
There will be a plate on the unit with it's electrical requirements.
If you don't have the unit... you post the make and model and I can check on it.
Old 08-29-17, 08:56 PM
D
The model looks like it's a Diamond 80. Model number G/UA024SA
Old 08-29-17, 08:59 PM
Diamond 80 is the furnace.
It only draws a few amps.
The model number needed is for the humidifier.
Old 08-30-17, 05:56 AM
D
The quotes are all for the Ultra-Aire 100V, or the Aprilaire Model 1850.
is Aprilaire any good?
Old 08-30-17, 10:20 AM
Aprilaire makes quality products. I'm not intimately familiar with that model.
The 1850 requires 8A of power. If your furnace is on it's own circuit..... it can be shared with the dehumidifier.
Old 08-30-17, 11:46 AM
D
Thank you for the information. Santa Fe returned my call and theirs uses 6.3 amps. I guess that is ok as well?
Old 08-30-17, 11:50 AM
Yes.... both can share with the furnace circuit.
Old 08-30-17, 12:50 PM
D
That's what I thought. The offers I'm getting are really running the gamut, there's literally a 2k difference in price. For the same hardware. The pricier one is saying they're going to run a separate circuit, install a drip pan, an emergency cutoff, tie into our existing air system, etc. It sounds though like the same basic thing that the other offers have.
Old 08-30-17, 04:52 PM
That type of dehumidifier is good if you don't have central air. Is that the case ?
Normally central air will combat a lot of the moisture and a self contained unit in the basement removes additional humidity down there.
If the basement is fixed up.... an overflow drip pan is a good idea. Safety shutoff too. The additional circuit should not be needed.
Old 08-30-17, 06:48 PM
D
That's good to know. We're planning to put it in line with the existing system. There's a large amount of the basement that is finished, but there's also a good bit that is not finished at all. The existing blower et al is in the unfinished section.
Old 09-01-17, 12:07 PM
D
OK The dust has settled and the rates are between 2500 and 5000. The difference seems to be in name only, I've heard Honeywell and also Aprilaire as the two units offered. What is the opinion on these?
