Joist blocking, what grade wood?
Old 08-03-18, 08:12 PM
G
I have 2x12x16 doug fur joist under my floor, I need a little more support spanning that distance. I wanna put 2x12 supports between my joist, should I use 2x12 doug fur or just a stander pine 2x12 for support blocks?
Old 08-03-18, 08:45 PM
Received 3 Votes on 3 Posts
If the area where the floor joists are located is climate controlled, you can use standard pine. If not, due to contraction and expansion, you probably should use Douglas Fur.
Old 08-04-18, 04:45 AM
G
Thank you I'll go with the douglas fur...
Old 08-04-18, 05:06 AM
XSleeper's Avatar
Received 675 Votes on 624 Posts
The species of wood does not matter. Use standard spf. You should be aware that blocking between joists does not significantly stiffen a floor. It must be very tight to do anything at all. The best way to stiffen a floor is to cut the span in half with a beam. And if that isn't possible, sister the joists.
