Priming back of purple board
Old 04-30-19, 08:41 AM
I'm planning to replace 8 sheets of paneling in the basement of a rural summer home with 1/2" purple board due to higher humid conditions. The back side of these 2 walls face an "L" shaped laundry/storage area currently has exposed studs. Need to keep it that way since there's a lot of shelving, cabinets, etc.
Main question is should the backside of the drywall be primed before it goes up? Someone suggested to leave the backside un-primed so it can "breathe".
Thanks in advance for your input.
Steverino
Old 04-30-19, 09:11 AM
P
Received 631 Votes on 583 Posts
In a bathroom it might want to breathe (though I've never heard of it before) because you have a high moisture environment on one side and a relatively dry on the other side. In your basement the humidity should be about the same on both sides of the wall so I don't think painting the back would cause trouble.
Old 04-30-19, 03:37 PM
Received 321 Votes on 285 Posts
As long as the backside stays dry there is no reason to prime the back. If the foundation walls don't stay dry - the cause needs to be identified and fixed first!
Old 04-30-19, 03:42 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
Who paints the back side of drywall??? If it's mold resistant that's all you need. Paint is for looks.
Old 05-01-19, 04:50 AM
P
I think the back side of the sheetrock is exposed in a laundry/storage room. I assume they want to brighten and neaten the look a bit by painting.
Old 05-01-19, 04:57 AM
If that is the case, there is nothing wrong with painting the backside - I'd paint the studs also.
Old 05-10-19, 09:00 AM
Had a lot of trouble logging in recently or else I would have said "Thanks" for all the replies/input earlier.
Aside from a local friend who mentioned this "breathing thing" I've never heard of it either. There is an excess humidity problem which is being addressed A small dehumidifier just never cut it.
For now the conclusion is not to waste primer on the backside.
Thanks again.
Steverino
