Water behind basment walls
Old 09-27-19, 09:49 AM
Instead of a full basement waterproofing (drainage around entire basment costing $10,000+) can i just get multiple sump pumps installed? I have 1 aleady but the sump is very small
Old 09-27-19, 10:03 AM
XSleeper's Avatar
Received 290 Votes on 264 Posts
You can put as many in as you like. But depending on the type of soil, they may not lower your water table fast enough to help the perimeter stay dry.
Old 09-27-19, 11:11 AM
Received 305 Votes on 279 Posts
Your idea is much like adding more bilge pumps to a leaky boat instead of fixing the leaks. Yes, you can add more pumps but you're removing water that's already entered the perimeter of your home. You are a power failure away from a sinking boat... I mean wet basement.
Old 09-30-19, 08:30 AM
Thanks
Thanks for the feedback. Are you recommending I work from the top down?
For example, make sure my landscape is graded properly?
Also i have highly acidic soil (new jersey)...I am not sure if that is relevant or not.
and my current sump pit is 11 x 11
