Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Basements, Attics and Crawl Spaces
Reload this Page >
Vapor barrier in crawl space: Placement relative to insulation blocks
Old 10-30-19, 10:25 AM
Question Vapor barrier in crawl space: Placement relative to insulation blocks
This question concerns a1955 house, in Virginia (zone 4). Currently it has an open (ventilated) crawl space, the height of the crawl space is 2 ft. Don’t see any water standing in crawl space.
I am about to put a new vapor barrier in my crawl space, and face some question. I try to put the vapor barrier up the wall of the crawl space (to 2” below the wood sill, per Virginia building code [2015, https://codes.iccsafe.org/content/VR...3_Ch04_SecR408 ]). Eventually I want to enclose & condition the crawl space, but not now. I read that insulation blocks are required on the wall and on the horizontal space at least 24”. I found James City County has a memo with illustration: https://jamescitycountyva.gov/Docume...quirements-PDF . (FYI: I am not in James City County, but this sounds relevant.)
Sorry for a long background. Here is the question: If there is insulation blocks, where to put them relative to the vapor barrier?
* Option 1: Vapor barrier between insulation blocks and brick wall?
* Option 2: Insulation blocks between vapor barrier and brick wall?
Does the building code say anything in this regard? It seems like either way is acceptable, because I did not see the code require exactly one of them. Any recommendation/comment?
Old 11-02-19, 12:16 PM
Received 59 Votes on 55 Posts
You want the water/water vapor to be kept away from the insulation so put the vapor barrier on the walls and then the insulation afterward.
