Drywall ceiling in basement
Old 06-02-20, 04:16 PM
I
In a room I am finishing in the basement, I am building a tray ceiling around the entire room, 1ft down from the ceiling and 2ft from the wall. Do I need additional support for the drywall on the under side of the tray? WHat I had read indicates that 5/8 in drywall can span 24 in but would like to confirm. Thank you
Old 06-02-20, 04:50 PM
XSleeper's Avatar
Received 938 Votes on 856 Posts
5/8 drywall can span 24". Any supports would be there primarily to help keep it running straight.
The thing you would need if the wall isnt fully drywalled is fire blocking in your wall 1 ft down. Otherwise a fire in the wall would jump into the soffit and up into the floor joists.
Old 06-02-20, 07:11 PM
Marq1's Avatar
Received 497 Votes on 461 Posts
But, you still have to construct the tray structure, so just make it 16" O.C. so you dont have to deal with two different thicknesses of drywall, overall it will be a simpler project only having to deal with one!
Old 06-03-20, 06:47 AM
I
Thanks for confirming the dry wall question. Where would I learn more about fire blocking? I can understand the need. just don't understand how it is done.
