Wrong nails into bottom plate
Old 07-27-20, 07:17 AM
I
Stupid mistake. I built a couple of small walls no load bearing walls in my basement. When tow nailing to the bottom plate (pressure treated), I did not use glavanized nails . Can I just add additional galvanized nails after the fact. Of do I have to remove what is there and start over.
Old 07-27-20, 07:29 AM
Marq1's Avatar
Received 356 Votes on 332 Posts
Being indoors I would not loose a lot of sleep over it!
Old 07-27-20, 08:20 AM
Received 75 Votes on 70 Posts
Untreated steel nails are going to rust out in no time when in contact with copper treated wood.
Only use ACQ approved nails.
Old 07-28-20, 03:13 AM
Received 300 Votes on 266 Posts
I wouldn't remove the bright/sinker nails unless it's easy to do so but I would add galvanized nails to insure the studs stay secured.
Old 07-28-20, 09:14 AM
I
Thanks everyone for the comments. Will add some galvanized nails. Stupid mistake. Glad I caught it now and not later.
