Basement flooring for home gym
Old 09-15-21, 08:47 AM
We have house built in 1965. We would like to install rubber matting in a quarter of our basement for a home gym. Each mat weighs about 100 lbs. and we would use approximately 14-16 mats. Would the concrete slab be able to support this much weight in just one section of the basement? The room is roughly 21x15 ft
Old 09-15-21, 08:59 AM
P
Received 2,014 Upvotes on 1,806 Posts
Yes, the concrete floor should be able to support the weight without much trouble. 3'000 psi is a common strength for concrete. Your matts probably are only ounces per square inch so the concrete will hardly notice the weight.
Old 09-08-22, 09:23 AM
Received 2 Upvotes on 2 Posts
I keep up to 4 tons of pellets on my basement floor at any given time. You'll be fine.
