Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Basements, Attics and Crawl Spaces
Reload this Page >
Membrane on wall - is vapor barrier still necessary?
Old 02-23-23, 12:29 PM
Received 2 Upvotes on 2 Posts
I looked around and couldn't find this issue. I have a membrane installed on the walls of my basement. I know that vapor barrier is full of opinions but, should I even consider a vapor barrier after I install insulation with this membrane already on the wall? The membrane goes under the floor and should be sealed at the top but some parts have pulled away from the wall
Old 02-23-23, 04:37 PM
Received 1,248 Upvotes on 1,192 Posts
Above or below ground? Have you checked local code?
Old 02-23-23, 04:59 PM
Below ground. I have not checked code, didn't realize there was a code for vapor barrier
Old 02-23-23, 05:14 PM
XSleeper's Avatar
Received 1,845 Upvotes on 1,660 Posts
The biggest thing you are lacking is fireblocking behind your wall at your top plate. You will have to follow your local code on the interior vapor retarder. IMO you should have put 2" of foam on the walls before framing went up. Kraft facing is OK, but I would not use poly.
Old 02-23-23, 06:02 PM
Thanks, that's interesting. I looked at Lowes today and saw the Kraft insulation next to Corning, I'd never heard of Kraft. Do you recommend it over the pink stuff?
Old 02-23-23, 06:12 PM
XSleeper's Avatar
Kraft is the name of the paper facing on any brand of faced insulation.
