Weirdly raised room advice
Old 03-23-23, 12:28 PM
H
So this has been bugging me since we moved into our fixer upper, there is a room under the main roof, which has a concrete slab on all 4 sides, yet the room is raised 36ft up in the air, with a dirt floored plastic covered vented space underneath ( no access to it though ) one vent is on the passageway side in the house and 2 vents outside.
it would make the room so much easier to use and incorporate into the house space if it was not up 4 steps, do you think it is possible to open it up and put a concrete floor in there or at least lower the floor height?
the room is approx 9x10ft
outside 2 vents
inside and passageway to the steps into the room
room steps
view through vent blocks from inside the house
Old 03-23-23, 01:13 PM
P
Received 1,845 Upvotes on 1,652 Posts
Yes, anything is possible. All it takes is money...
It looks like the walls bordering the raised area have their own foundation walls & hopefully proper footers underneath. That should make it easy to remove the raised floor while leaving the walls in place. Then you can remove however much dirt is needed to allow pouring concrete to match the other, adjoining rooms.
Hurleyfx voted this post useful.
Old 03-23-23, 02:02 PM
H
I was hoping that was the answer thank you.
Old 03-23-23, 04:45 PM
B
Received 243 Upvotes on 216 Posts
Are the ceiling joists in this room at the same elevation as the ceiling joists in the remainder of the house? A photo of how this room connects to the rest of house and roof would help.
Old 03-23-23, 05:55 PM
H
Yes the ceiling is the same height as the rest of the whole house, the main body of the house sits on the same level as this, connected by a passage, but the one side of the house is down on the same level where this is, but this then is oddly raised.
Old 03-23-23, 05:58 PM
H
The main body of the house has 7'6 ceilings apart form the vaulted living room. the extended part of the house where this is located has much higher ceiling, ( approx 9.5ft, i have not measured exactly) apart from this room which has a lower ceiling.
id just like to have not to go up steps to get in.
