Rim Joist Insulation
Hi All
Any recommendations for a one part, closed cell spray foam. Want to spray 2 inches.
Have 150 linear feet by 25 inches.
Chicago Zone 5.
Thank You
Chicago Zone 5.
Thank You
If you have never used those kits they are a PITA. Used once to repair some insulation I had to remove on my spa with a leak. It simply did not spray a nice uniform width/depth and ended up dripping all over the bottom of the spa and falling off the existing foam, not something I will ever use again, at least if you're looking for something relatively clean and neat.
Dont recall the specific kit but it was a 2-part closed cell foam.
That's a lot of foam, might want to consider the foam panels cut to size!
cwbuff
voted this post useful.
Spray Foam
Hi
I would use foam blocks but the rim joist were sprayed by the builder and not a flat surface to mount panels. I'm afraid that the voids/gaps would promote condensation. The gaps I'm referring to are between the foam and foam board NOT the perimeter
I'm very hesitant to do a half ass job and end up with a problem.
Not looking for a smooth finish since I will be drywalling the ceiling. 2-3 inch layer with no batt insulation.
I'll check out the DAP, hopefully it's a 1 canister set up.
Thanks!
Thanks!
If it's an irregular 2" gap you could try the Great Stuff for large gaps in the big cans and use their dispenser gun. You'd need a pex extension and pipe clamp... and do it in layers.
